sparky
fiat218
sparky
Post by fiat218 »
where does the orgin juice come from to make the spark
battery/ to coil/ to dizzy/ to plugs/ VERRROOOM?
OR WHAT
124JOE
Re: sparky
Post by 124JOE »
the ingition
batt,key,coil,dizzy,plugs.
fiat218
Re: sparky
Post by fiat218 »
oh ya, i forgot that part lol
so if ther no spark and i changed the modular and the rotor and cap and new plugs and coil and magnet coli ? what ever u call it ,. and still no spark. wwhat eles is ther
124JOE
Re: sparky
Post by 124JOE »
test the positive wire from the key,if nothing with key on then your ignition is probably shot
fiat218
Re: sparky
Post by fiat218 »
if testing a voltage reg on the car, key on, would there show power to both sides , testing with a test light only
thanks
ok if both sides are powerd up and i connect the modular to the wires that it suppose to be,should ther be power on the outlet part of the modular?
fiat218
Re: sparky
Post by fiat218 »
ME AGAIN :)
no spark off the coil itself, tested 12 v on plus side and neg side. took and hooked up the coil wire and tested for any spark
NONE
bad coil ? right
124JOE
Re: sparky
Post by 124JOE »
fiat218 wrote:ME AGAIN :)
NONE
bad coil ? right
bad coil or wires,but probably the coil.joe
fiat218
Re: sparky
Post by fiat218 »
thanks, i hope so :lol:
aj81spider
Re: sparky
Post by aj81spider »
You don't say what year you are having the problem with. If it's a later model year, I had that problem and it was the ignition control module mounted behind the coil.
A.J.
2006 Corvette
fiat218
Re: sparky
Post by fiat218 »
sorry 1980
i replace the modular, pickup and roter
can a person check the modular ?
aj81spider
Re: sparky
According to the factory manual if you have voltage at the coil and the coil resistances are good then you disconnect the high voltage wire at the distributor and hold it 5 mm from ground and crank the engine to see if you get a spark. If you don't then you replace the module.
According to the manual coil resistances should be 0.75 to 0.81 across the primary and 10-11,000 from primary to secondary.
A.J.
2006 Corvette
fiat218
Re: sparky
Post by fiat218 »
from what i was just told now from a mechanic. IF i got power to the negitive side WHEN just the key is on, there something wrong, there shall be no power to the neg side untill the engine is turning over as in fireing
well there power to neg when the key is on the on position
so what wrong ?
