VOLTS
fiat218
VOLTS
Post by fiat218 »
what the volts that are suppose to be on the 1438 engine,1969
i have a good alternator and relay and suppose to be a good voltage reg
i have 14.9 at idel and 15.6 and high rpms
is this right or wrong
redcars
Re: VOLTS
Post by redcars »
You should have 13.8 to 14.1 at all rpm if the battery is not way low on charge.
Cheers
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
fiat218
Re: VOLTS
Post by fiat218 »
ok thanks. what would cause a high volt reading
baltobernie
Re: VOLTS
Post by baltobernie »
Bad battery or bad regulator or bad wiring
What is voltage at battery terms, everything off?
