IDIOT LIGHT
fiat218
IDIOT LIGHT
Post by fiat218 »
LIGHTS on
charging is all good,
igot that checked. i made sure the wires on alternator was on good
i replace the regulator, nothing change it, i did the removable of the battery cable to see if it stayed running that was ok
i turn the lites on, they where still up to par on brightness, so that ok ok
WHAT NEXT
bradartigue
Re: IDIOT LIGHT
Post by bradartigue »
Probably a bad ground somewhere; if it is any consolation some cars do this and there isn't really a cure. If the light goes away when you rev up the motor or turn off the lights (or turn on the lights) then you can hunt for a bad ground.
fiat218
Re: IDIOT LIGHT
Post by fiat218 »
it stays the same. does not flicker or dim,bright, stays bright no matter
mdrburchette
Re: IDIOT LIGHT
Post by mdrburchette »
The idiot light on the early model cars is controlled by a relay. Make sure your connections are good from thealternator to the regulator to the relay, then to the lamp.
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
fiat218
Re: IDIOT LIGHT
Post by fiat218 »
thanks i have not done that yet
