Turn Signal Woes SOLVED
Zulu
Post by Zulu »
UPDATE: A lot simpler issue than I feared, just a corroded connector.
I have the bumpers removed on my '75 Spider, and so I have just put in some temporary marker lights I got from Pep Boys, wired up as the front turn signals and mounted to the front grill. The left signal works, in the front and the back. The right rear turn signal does not work, however the right front turn signal comes on very lightly, non-blinking. I have checked continuity on the light socket for the right rear, and the bulb is good. The hazards do not work at all.
From what I have read, the turn signals and hazard lights all use the same flasher, and so now I am at a total loss. Any help is appreciated, thank you.
-Austin
seabeelt
Patron 2019
Patron 2019
Re: Turn Signal Woes
Post by seabeelt »
Did they work properly before you removed the bumpers and installed the aftermarket ones? If so, its probably in the wiring that you used to attache the new lights with; Otherwise you will need to get a test light/multimeter and a copy of the wiring diagram to start your troubleshooting. Start from where you have the problem and start working backward until you get good voltage and a good ground.
Zulu
Post by Zulu »
Thank you for the advice, but it was a lot less complicated than I feared; one of the spade connectors was corroded. I feel kind of silly now for making the fuss.
