hazard lites/signal lites
ronz124
Post by ronz124 »
I have a new to me 1980 pina that has me stumped...does the hazard lites and the signal lite use the same flasher?...my signals work fine but I get no joy with the hazards, any clues? thanx ron
billstyer
Re: hazard lites/signal lites
Post by billstyer »
They both use the same flasher. Best guess - bad ground (1st guess) - could also be faulty connection or bad hazard switch.
Here is a link to the wiring diagram - http://www.artigue.com/fiat/wiring/Wiring_1980_1982.pdf
Bill
mbouse
Post by mbouse »
second guess is a bad hazard switch. expensive to replace, but easy to swap in/out.
possibly a rebuild may do the trick:
http://flumichigan.italiancarclub.com/T ... switch.pdf
zachmac
Post by zachmac »
As per the referenced wiring diagrams, Fuse 1 feeds the flasher through the hazard switch. This is a switched supply that only has power when the key is "on". When you trun the hazard switch "on" it should send unswitched power from F9 to the Hazard switch to the flasher. Is fuse 9 good?
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
jdeight
Your car is a: 1980 2000
Post by jdeight »
if there's a more current link to the italiancarclub.com rebuild that @mbouse links to above, would you please post it here? thanks.
