Front Bumper Shock bolt keeps turning...
Today I began removing my front bumper shocks, I got the drivers side off without a problem but the passanger side bolt which holds the bumper shock in just keeps turning. I've got an idea of why: the bolt is probably bent as the frame rail shows indication of crash damage and the bracket which holds the shock is bent and missing a bolt. Any ideas of freeing the bolt or am I basicly screwed?
- SLOSpider
- Your car is a: 1973 124 Spider 2.0FI
Re: Front Bumper Shock bolt keeps turning...
Well you can try to wedge a screwdriver between the bracket and frame rail to create some tension on the bolt while you try and remove it.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
