Before I start. Aussie's call the rear axle a "Diff" as in differential.
Have removed the diff to look at a number of things, It's easier than working under the car. Anyway, the diff was leaking at the mating face where the drive shaft bolts to the diff. Suspecting a worn seal, discovered that the leak was not from the seal, but along the spline, around the washer that is held in place by the nut and out between this mating face.
What I want to know is how do I seal oil running along the spline to the mounting washer and nut.
The nut was tight and the washer looks quite smooth (cannot see leak path)
Here are a few photos.
Manufactured a removal tool. Copy of A.70345. Half hour side job that save much time.
The mounting side is 'oily'. Evident of a leak here. Plus the small puddle on the ground.
The oil seal side is dry, albeit dirty. No oil leaking past the seal
How do I seal the face between the washer and the drive flange?
Schematic for your reference
