Simple question: On my '78 how do the side emblems come off?
That's all!
Side emblem removal
- TulsaSpider
Side emblem removal
Re: Side emblem removal
They do come off, but there were two designs. The early models were threaded and held on by 4 or 6 mm nuts. You have to take the two quarter trim panels out to access the nuts. The later models just popped in and were held by clips. You may be able to pry them off but I'm not sure. I don't know when the design changed.
Hi Clark, did you get the emblem off? I'd guess it's most likely the later style that has two posts that are held in place by clips on the inside of the body panel. You can usually pop them off by using a plastic grocery bag, slip it behind the emblem and pry out. A little wiggling may help.
- Your car is a: 1981 Spider Turbo - missing the turbo
Wiggle what - the plastic bag or your own bodyrlux4 wrote:A little wiggling may help.
THE FLEET
2014 Abarth "SS"
1981 Spider 2000 (Legend Industries Turbo - minus the Turbo)
1978 X1/9 1.3 Dual IDF 40's, Coupe Cam, Allison Header/Exhaust
1971 128 Sedan 1100cc, Coupe Cam/Headers
Motokhana Special 127 rear engined Rail 903cc
2014 Abarth "SS"
- TulsaSpider
I was wiggling! They seemed to have been glued on. Yup I got them off! Thanks!
Good one Adrian. I guess I did leave that up in the air.
