Dreaded Top Hinge Another fix & Reinforcement
SpiderJim
Post by SpiderJim »
A few days ago I was reading Mike Bouse hinge repair and thought to take a look at mine now that I'm in the middle of a restoration. Ouch! I had it bad on the drivers side top. Completely cracked all around and ready to fall to the curb. I had to cut a large section of the door inner panel to get at it. See the following link for pics if it helps you. After the repair I refitted the hinges and door to check the alignment after adding the support plate that is just a tad thicker than the hinge support metal. Seeing that I'm doing a full restoration and expensive paint job I would rather know now if I had a problem with fit. Adding this plate does not cause any issues with alignment and lots of extra adjustment available.
Hope this helps someone....
Picture Link & other Fiat stuff under Home Segments --- > http://gallery.me.com/jamesaellis1#100186
Foster48x
Re: Dreaded Top Hinge Another fix & Reinforcement
Post by Foster48x »
Nice pics Jim.
Rick
mbouse
Post by mbouse »
yup, more pics are always good. glad you caught it in time
narfire
Post by narfire »
Hmmmm.. after that,I might have to bite it and look at the pass side of my 80. From the rear of the door,I can lift it and see a bit of movement at the hinges. I've always thought the doors did'nt close just right.
The car is going in soon anyway to get a bit of body work done... :cry:
The jack broke free in the trunk(did'nt have secured properly) and the end where one attatches the ratchet, slamed into the inside of the fender,leaving a couple of dings on the outside of the fender.
Thanks for the pics Jim.
