Steering wheel, hub, and mirror questions
Getting some stuff done while I can since it's cold outside. I cleaned the steering wheel and it came out pretty nice. I have to paint the center now. Does anyone know what the original silverish color is called. Maybe I should just paint it the top color of my engine.
Has anyone made an extension for the hub. I'm not sure but I think I would like a 4" extension. I have long legs. Do you think 4" is too long?
I also need to know what should I use to clean my mirror. I tried glass cleaner and pumice. it looks like there was water on it and it dried.
Re: Steering wheel, hub, and mirror questions
Are you having a problem with the mirror or the glass cover over it? In either case, being in the replacement window business, I see a lot of glass that has been acid etched from too much contact with water. That can't be removed, as it's etched into the surface.
That's not water that's dried on the mirror. Someone pasted a picture of the inside of a house on it!
In the pictue though, it looks like fingerprints. Is it like smudges? There is a product called jewler's rouge that can clear up glass. It might work better than pumice. It can be bought at Lowe's as an accessory for the dremel tool.
I got the steering wheel almost done. Tomorrow I'm going to clear coat it to seal it. I was going to paint it but saw how nice it was brushed. Here's a pic.
It looks good. What did you use to brush it with?
I used an air tool with polishing discs to remove the paint. I went from medium to fine. Got it all cleaned up and then used a sandpaper sponge to brush it. I didn't want the steering wheel to overpower my gauges.
Great looking wheel, Brady!
I bet this adaptor would work. Your wheel appears to have the same dish as mine.
http://www.international-auto.com/steer ... apters.cfm
It is sold to fit the IAP wheel that Santa brought.
Two cautions for anybody using this adaptor - First, use a sanding block and 400+ paper on the big end. Overspray and rough casting will tear up the Fiat horn nibs. A little dielectric grease here, too. Second, use sandpaper or a Dremel drum on the inside of the small end, so that the IAP horn button can make earth contact. BTW, the horn button is made from a grille emblem from an early car. 2-3mm too wide, so that's another job for the Dremel.
Yes, I know the dash wood is now the wrong color! I'm working on it ... (it's a long Winter)
I have the hub for my steering wheel. I was interested in getting an extension to bring the wheel closer to you.
azygoustoyou wrote:Getting some stuff done while I can since it's cold outside. I cleaned the steering wheel and it came out pretty nice. I have to paint the center now. Does anyone know what the original silverish color is called. Maybe I should just paint it the top color of my engine.
1. Silverish is the official color's name.
2. Black Crackle works nice too.
oh, wait.... i see you already decided. nice looking wheel. you can always go to black Crackle paint at a later date.
If anyone decides to do what I did. I wanted to let you know about clear coating it. I went to Autozone and bought some Rust-O-leum clear. It works great. Just make sure the wheel is clean. I got a couple pieces of fuzz on it. I'll try to polish them out. Anyways it look 100% better with a shiny sheen to it. When you go to paint it. Make sure you paint the back first. Or you'll have overspray on the front like I did and you'll have to respray the front again.
Brady,
The fiat hub and wheel use a momo bolt pattern. Look for a momo hub extension and it will fit on yours.
Scroll to bottom page, they have two.
http://www.pelicanparts.com/catalog/Sho ... detail.htm
http://www.pelicanparts.com/catalog/Sho ... l_pg25.htm
