What are these things???
I found these in a box of parts that came with the car. They are marked left and right and have what look to be electric spade terminals. What are they? Thanks in advance for some help.
Re: What are these things???
Looks similar to the hooks that are used to pull out the car stereo, hard to say when there is no size reference
Its hard to tell the size of the items on my phone but they look like keys to remove a radio from the mounting bracket. If. You have a flat faced radio check for a couple holes on each side.
Ive taken apart lots of spiders, never seen those.
Thanks for the feedback on these, the comment from spiderry was what I needed to hear. As far as size, the center square is a little bit bigger than if I lay a quarter in it. Must be for the radio, which is going in the trash so I won't worry about where they go.
that is a matched pair of gazintas !!
the pointy part gaz in ta something...
You've found Elton John's missing broken spectacles!
