As a lot of you are aware,Denise and I have a Lemons race car.We ran out of time for the fall race last year,but have high hopes of 2 or 3 races this year.Denise's husband,Ron,is a former Nascar Busch crew chief and a ARCA owner/driver.He is armed with a garage full of tools and vast ammount of knowledge.He has rebuilt the motor we tore up last year,and had me come over today to get the front end set up,and see if it would move!!The 3 of us spent most of the day setting camber ,caster and toe.Got it perfect(with a little creative engineering on the control arm
).So we put in gas,I climbed in,and we fired her up.
The Good....It runs awesome!!! Will light the tires up,idles smooth,great pickup,sounds badass,no leaks.
The cars steering is light,handles like its on a rail,and the stance(cut 2 coils front and rear) is great.
The Bad....Tranny
We have no 2nd gear.it wouldnt downshift into 2nd on my first run.I had Denise try ,after we adjusted the clutch,and same story.I tried again and it just wouldnt downshift into 2nd,although the upshifts were smooth.Then Denise tore it up completely on her last run
We also have some issues with the driveshaft hitting the tunnel,and possibly the panhard bar is tweaked.
The Ugly.....we continue to 'lighten' the car.Every time you touch it,metal falls off!!
So....one step forward,two steps back.We are going to be needing some help with parts and knowledge from you folks.Denise will post our wish list,and hopefully some pix soon
