I found that when I dial my motor to TDC the water pump likes to leak (I had a feeling that the berings were going out). HMMMM
. I've been looking at it from every different angle and it seems that I can just take it out without removing the timing belt but I have been hearing different from others. Can the water pump be removed without taking off the timing belt. Maybe when they are saying timing belt they really mean the other belt.
Other notes - switched out the distributer this past weekend and replaced the points with the electronic distributor - Thanks Mike R. for all your help. Makes a real difference
Found some shorts in the fan system - Just popped on while cold, sitting and without the engine running or ignition on- could account for those times I have a dead battery for no reason. Also, popping fuses to that system as well - FUN FUN FUN
