I have a quick question concerning wheel lugs. I recently purchased a set of the wheels pictured below. I noticed that in order to mount them I'm going to need wheel bolts that are longer and have a slightly larger bulge seat. The stock lugs are not quite big enough to seat properly. They're also not long enough since the wheel mounting pad is thicker. I've seen a couple of options both on eBay and at IAP. The ones I think I need would be the Panosport wheel bolts, IAP part number 39867. These appear to be longer with a bigger bulge seat. Can anyone confirm that these lugs will work with the pictured wheels?
Thanks for the help!
Josh
