I can't seem to get my right front running lights or my left rear running lights working. It seems that they both run off the red\yellow wire but I can't seem to find where the two intersect ON THE CAR. THe White\black wire from the switch is good and attached so, I think the wire is broken or chewed by mice or rats somewhere between the fuse box and where the two connect.
Yes, bunch of my wires have been chewed through.
On the bright side, I have managed to re-connect the following by using the wiring diagram.
Front left and right turn signals
Driver's side front running lights
Passinger side rear running lights
passinger side rear turn signal.
Dash Lights
Cigarrette lighting system and courtesy light (actually works when the door is opened).
Front headlights and Hi\low beams.
One final thing. I have a double ground wire that looks like it goes to the fuse box that is just hanging there with a white clip thing on the end. It's not the one that goes to 9 or I (Fuse Box) on the Parking\side marker lights wiring page but looks exactly like it. When I kinda jam it in where it looks like it should go, it just makes the headlights turn on or the running lights turn on depending on the area I shove it in - without using the light switch . No smoke or burnt wires yet. YET!!
