Shifter spinning
BoyleC
Your car is a: 1978 Fiat Spider 124
Shifter spinning
Post by BoyleC »
I have ‘78 Spider, 5-speed. Shifting is smooth. However, the shifter (not the knob) spins. I think that only the upper lever is spinning as is freely rotating on a tight axis—like unscrewing a bolt or screw. I am considering replacing the bushings/clips that connect the upper and lower levers to see if this will fix the issue. I’m a novice and would appreciate any feedback/thoughts.
Online
bobplyler
Patron 2022
Patron 2022
Re: Shifter spinning
Post by bobplyler »
That's working the way it's supposed to. Mine has been doing that since new.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
As mentioned above, many of the shift levers spin. However, while they can turn if you turn them, the chrome shift lever extension should not freely rotate on its own. Or rattle.
As you mentioned, you might have missing or worn out shift lever bushings:
https://autoricambi.us/shifter-extension-bushing-kit/
BoyleC
Post by BoyleC »
Bryan/Bob,
Thanks for the response. Very helpful.
Chris
