1983 Spyder Repair Atlanta Area
- Your car is a: 1983 Pininfarina Spyder
I have a 1983 Pininfarina Spyder which does not want to start in Atlanta, GA. Starts in cold for 1 second then stops. Fuel pump working. Need mechanic. Any suggestion ?
Re: 1983 Spyder Repair Atlanta Area
Try looking up Brad Artique at Mirafiori.com. He lives in the Atlanta area and is one of the gurus for Fiat spiders. Even wrote a book on them.
Open the plastic cover on the AFM near the air filter. Move the flap in the AFM and with the key on and you should be able to see the fuel pump connector and ear the pump turn on. Check the condition of the track inside the AFM and be shure that the flap move freely.
- Your car is a: 69 AS Spider
Hi and welcome!
it would be nice, if you introduce yourself to the audience after joining the forum. And we are always interested in seeing new pictures!
The worldwide Spider Register counts several 83 Spider in Georgia. Is your car already listed?
https://www.fiatspider.de/register?Fahr ... ve=Georgia
Would be nice to get your car data plus pic..
Good luck with your problem!
Cheers Ralf
Cheers Ralf
69 AS Spider
the Worldwide Spider Register
