TX82FIAT wrote:Well, now you have me second guessing myself as the bleed screw should be facing slightly up in order to be a bleed screw to be effective. On the FI cars the bleed screw is on top and the temp sensor is below that. I've attached a picture of a 79 t oulet to see if that helps.
I have the exact same bleed screw as the one I can see in your picture, but mine is on the bottom.....
Nut124 wrote:Common sense would say the restriction should be towards the water pump. This is how the fluid flows when the engine is cold. The restriction maybe there to provide some backpressure so the cabin heater would flow/work if needed.
When the engine is hot, coolant flows from the head to the top of the radiator and any restriction would hurt cooling.
That was my feeling - common sense suggests there shouldn't be any restriction towards the radiator.... That's why I have queried it.
Odoyle wrote:On my 77, 79, and 83, the restricted side of the t is facing the exhaust side (thermostat side) and the fully open port connects to the radiator.
That's extremely useful, thank you. I think based on what you posted and the other posts above my car has it's T-piece fitted upside down and the restriction is facing the wrong way..... I'm going to whip that off and re-fit it the other way up. Hopefully that will help restore my cooling system to better functionality....
