Crossmember fix or replace?
Italfiat79
Your car is a: 1979 Fiat Spider 124
Post by Italfiat79 »
I recently bought a 79 Fiat last fall and I’m debating what to to for the crossmember issue. There is a hair line crack which needs to be fixed to pass inspection. So I’m wondering if I should get it professionally welded with a bracket or should I attempt replacing it.
If I decide to replace it, does anyone here have the experience removing the crossmember without pulling the engine out? Thank you, Mike
Yadkin
Your car is a: 1974 Spider
Re: Crossmember fix or replace?
Post by Yadkin »
Find a local custom car shop and bring it to them.
Italfiat79
Thank you, will look into that.
Italfiat, thanks for reposting in this section, and for others who may be interested, here's another "tip".
Contact wetminkey on this site, as he's dealt with this before. See: http://www.fiatspider.com/f15/viewtopic ... er#p299772
wetminkey
Post by wetminkey »
A frame and body man repaired my unibody frame members, so that my crossmember would bolt up tight. And he completed an Abarth racing 'through-bolt' alteration (that I found on this forum), at the same time, to improve upon the 'ill-fated' Fiat engineering of this. I think the 'plans' are on my thread,...
I did all of the disassembly and reassembly, etc,...but I only spent $600 for the work. And the frame/crossmember are rock solid! And afterward, the car aligned perfectly. Drives like a dream,...
PM me here for further info,...I'm glad to help.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Italfiat79
Hi Todd,
Nice job! And you didn’t spend whole bunch.
Car is put away for the winter but as soon as I can take it out I will disassemble and inspect before anything.
Thanks for your time, much appreciated.
Cheers!
Mike
