Measurement for honeycomb grill
- Your car is a: 1978 Fiat Spider 1800
Hello,
I am trying to find cheaper alternatives to fabricate a honeycomb grill and wanted to ask a favor.
Would any of you know owns one measure the cells for me, please? I would like to know how big/small (width/height) the cells are,
thanks in advance for any help,
cheers,
Abel
cheers,
Abel
Re: Measurement for honeycomb grill
Anybody? Nobody?
On my '71, the openings in the honeycomb structure are a little over 1" wide by a little less than 0.5" high. More accurately, it looks like 1 and 1/16" wide by 7/16" high, but that's just holding a tape measure up to my grill. I can try to get more accurate if you want.
Thanks Bryan, I appreciate your reply. With those measures I can try to find something closer to the original.
cheers,
Abel
cheers,
Abel
- dinghyguy
- Your car is a: 1981 spider
https://www.mcnichols.com/expanded-meta ... s-58001213
How about something like this?
cheers
dinghyguy
cheers
dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
that looks interesting. I need 0.40" x 0.80" more or less but I cannot figure out if this would be the one I need.
I do not know which is what from these measurements:
Design Size - Short Way of Diamond (SWD) 0.480"
Design Size - Long Way of Diamond (LWD) 1.260"
Opening Size - Short Way of Opening (SWO) 0.269"
Opening Size - Long Way of Opening (LWO) 0.854"
Does anybody know?
cheers,
Abel
Does anybody know?
cheers,
Abel
Hi Abel. Based on the dimensions Bryan gave you. I think one of the 1/2" sizes on the attached link is what you are after. Probably 12"#13. I think the other 2 may be a little flimsy. You want raised expanded, not flattened if you want the same 3 dimensional look as the pic. Although the shape isn't identical. If you scroll to the bottom of the link page it shows you how these are measured. Generally you have to buy these in 4' x 8' sheets. If you know anyone that works for a steel fabrication shop they may be able to help you. If not you may find approaching a local fabrication shop may have a crop they would sell you sometimes for cash for their beer fund. It helps to know what you are after. They are more likely to go have a look if you talk their language.
https://www.accuratescreen.ca/assets/sp ... Raised.pdf
Looks like these guys will sell smaller sizes.
https://www.metalsdepot.com/steel-produ ... nded-metal
Or stainless would be nice.
https://www.metalsdepot.com/stainless-s ... nded-metal
Good luck
Good luck
Dave Kelly
Campbell River B.C.
1973 Sport(sold)
Campbell River B.C.
1973 Sport(sold)
If you just need a new (used) grill, my friend JT in San Francisco is selling one on Ebay:
https://www.ebay.com/itm/174861388786?h ... Sw6hVhAMr5
I've seen the grill in person, and he did a nice job with it. I can't speak to the price, but it seems reasonable given that this particular grill style is not super common (at least for one in good shape).
Hi David,davidbruce wrote:Hi Abel. Based on the dimensions Bryan gave you. I think one of the 1/2" sizes on the attached link is what you are after. Probably 12"#13. I think the other 2 may be a little flimsy. You want raised expanded, not flattened if you want the same 3 dimensional look as the pic. Although the shape isn't identical. If you scroll to the bottom of the link page it shows you how these are measured. Generally you have to buy these in 4' x 8' sheets. If you know anyone that works for a steel fabrication shop they may be able to help you. If not you may find approaching a local fabrication shop may have a crop they would sell you sometimes for cash for their beer fund. It helps to know what you are after. They are more likely to go have a look if you talk their language.
Good luck
thanks for the links. Earlier on my online search, I had found metalsdepot but I got the impression that they were geared more towards the industrial side (i.e selling in big quantities). I will contact them and see if they might sell small 20" x 40' pieces,
cheers,
Abel
Hi Bryan,18Fiatsandcounting wrote:If you just need a new (used) grill, my friend JT in San Francisco is selling one on Ebay:
that grill looks quite nice...although a bit pricey for my budget. That's why I thought of trying to make my own, but I will keep your friend's in mind,
cheers,
Abel
Abel if you click on the select size box it gives you a price for a bunch of stock sizes as well as custom cut sizes. In retrospect i'm thinking 1/2-13 is too heavy. I think 1/2-16 would be more suitable.Hi David,
cheers,
Abel
Dave Kelly
Campbell River B.C.
1973 Sport(sold)
Campbell River B.C.
1973 Sport(sold)
Hello,
in the end, it was actually cheaper and easier to buy the original grill.
Now, there is a new question. How do you install it into a 78 model? I can get it inside the gap removing the chrome surround, but I cannot rotate the grill to face the front. Has anybody installed this kind of grill before? What kind of modifications are necessary?
cheers,
Abel
cheers,
Abel
Hi Abel, I can't tell you how this grill might fit in a '78, but I can tell you how it is attached in my '71. There are 4 mounting points, 2 on top and 2 on the bottom. The top has a metal bracket about 14" long or so, and it is attached to the grill in 2 places. That bracket is then attached with two screws to the crossmember right in front of the radiator.abelclasico wrote:Has anybody installed this kind of grill before? What kind of modifications are necessary?
On the bottom of the grill, there are two L-shaped brackets attached to each lower corner of the grill, and the flat section of these is attached into a tab on the body opening for the grill. This tab on the body points inwards (towards the radiator).
I'm not aware of any differences in this opening between '71 and '78, but I do recall having to work a while to maneuver the grill into position in that opening.
Hi Bryan,
thanks for the information. When I removed the original grill, the tabs came of the cross members but I will be reattaching them into the new grill.
The hardest part has been to figure out how to insert the grill into the aperture. I might need to do some surgery to the grill for that.
Thanks for the help,
Abel
Abel
This is tricky, and maybe it doesn't work in your case, but I have inserted the grill horizontally into the aperture with the short end going in first, and then right before you poke a hole in the radiator, slowly rotate to the vertical position and with the long side facing you, into position.abelclasico wrote:The hardest part has been to figure out how to insert the grill into the aperture.
