A while back I bought a bushing kit for my 71 coupe. These are rubber only and I suspected you are supposed to reuse sleeves and such from the original parts. Only one little problem... Stock bushings are two-piece, replacements are one piece. That's not the issue though. The stock pieces have a sleeve were two spacers/washers fit on the end. After 50 years of service these had to be cut apart and will can not be reused again. Now I am trying to find replacements but none of the parts I find look like the originals. The sleeves are not machined for spacers/washers and none seem to sell these spacers/washers anyway. Not even if buying complete new trailing arms these pieces look the same.
So was there a change somewhere? Are the sleeves not the same any more? Are even the spacers/washers used with these new style sleeves? Even if I would buy sleeves or the complete trailing arms with bushings I would seem to be missing the spacer/washer which I have now on each side of the bushing.
I found a picture. part 4183260 is the sleeve. These are machined to take the washer 4183261. Replacement trailing arms and sleeves do not look like this
