I noticed that my spider takes much more time on startup as of late (cranking is longer). Once started it runs fine and I would say the starter speed also seems normal.
I do have a parasidic power drain (batt looses charge over night) that I need to source, however, the starting is slow even when the battery is fully charged.
I was wondering what servicable parts of my ignition I should be replacing. I have a 77 that was converted to electronic ignition about 15 years ago. The work was done by a very reputable shop in Montreal and I had no issues till last year. The ignition was sourced from an 82 FI car and I have never changed the cap, rotor, magnetic pickup or coil. (plugs and wires are recent). I also plan on using some carb cleaners just to make sure my problem isnt fuel.
Aside from replacing the servicable ignition parts I mentionned above are there any recomendations?
Slow Starting
Re: Slow Starting
Fuses 9 and 10 protect many of the "hot all the time" circuits in the car. There are others that are not protected. Have you removed fuses 9 and 10 to see if that removes the battery drain?I do have a parasidic power drain (batt looses charge over night)
As far as the slow starting goes, that could have many causes. I believe the solid state ignitions need at least 10 volts measured at the coils B+ terminal when the engine is cranking. If that voltage is lower than 10 volts the ignition may not produce the proper spark. Does the car seem to start the instant the key is released from the start position. If so it could be eith low voltage or a failing ignition switch.
Re: Slow Starting
Dino, I'd pursue what spider2081 mentions above, and I'll also ask: What model carburetor do you have, and what type of choke (electric, thermostatic, manual)? Any chance that the choke has stopped working correctly?
- kilrwail
Re: Slow Starting
Do you still have a mechanical fuel pump? They are always harder to start, which will get worse if it's failing.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
