Pertronix revisited
CharlieB
Your car is a: 1976 Fiat Spider
Pertronix revisited
Post by CharlieB »
Well my neighbor down the street has the Pertronix system that fits my car ('76 Spider).
We are going to hook it up and see what happens.
My question is, what do we do with the 2 wires that are currently connected to the 2 points? (One wire on each point)
One of the wires is green, the other is black (maybe) its hard to tell.
Do we just cap them off?
Charlie
1976 Fiat 124 Spider
CharlieB
Re: Pertronix revisited
Post by CharlieB »
So we tried starting the car with the 2 wires not connected and it does not start.
Akspider
Patron 2019
Patron 2019
Your car is a: 1972 124 Spider
Post by Akspider »
Would think those wires can be left disconnected and capped off as they're routed thru the start/run relay contacts to the coil which should now be bypassed by the Pertonics ignitor. There's a troubleshooting procedure on Pertronix's site for the MR-LS1 setup (not sure what one you have installed). https://cdn.shopify.com/s/files/1/0247/ ... MR-LS1.pdf . I have Pertronix installed in my Comet with just the stock coil and it works great. Good luck! :)
Anchorage, AK
2013 Kia Sorento (gets me to the parts store)
1972 Fiat 124 Spider (Fix It Again Tomorrow (maybe)!)
1966 Comet Caliente Convertible (the fair-weather summer cruiser)
CharlieB
Post by CharlieB »
Thanks for the response. We did get it started last night. I had to turn the distributor counterclockwise, further than it was when I had the points installed. Not sure if that is normal or not, but it is running. It's idling higher than it was before, but not too bad.
I don't have a timing belt cover or the mark pointers, but I'll try to check the timing tonight.
Thanks again,
Charlie
CharlieB
Post by CharlieB »
AK, the link you sent is exactly the unit that we installed, so thanks for that.
