Hard fuel line replacement
Posted: Fri Dec 27, 2019 7:18 pm
I am looking to replace the 4 hard steel fuel lines on my '78 Fiat Spider (Carbureted) as two of them have rust damage beyond repair. I have not found that any of the usual suppliers carry fuel lines on their web site. Does anyone know of a supplier of fully formed hard fuel lines for the spider?
If not, has anyone fabricated the fuel lines? A few challenges I see...
1) not sure how to put a bead on each end to hold the hose with a hose clamp. I checked with 3 local industrial hose companies and all say they can't do it. It seems maybe putting a bubble flair on each end may work? or maybe don't crimp the bubble flair fully to give just a mild bead? Thoughts?
2) I would like to make it in stainless steel to prevent corrosion and rusting, especially given it is under the car? I believe it will be difficult to bend, but I like the corrosion protection. Thoughts or experience on using stainless steel?
3) One local supplier suggested using Bundy tube as it is more flexible. He said it would be fine for fuel, but I am not so sure... anyone have experience with using Bundy tube for fuel lines?
4) Also, the tubes are 6mm (return) and 8mm (supply) OD. It appears that it is much easier to get 1/4" and 5/16" line which are close. It seems that since I will be connecting both ends of tuning to a rubber hose with fuel hose clamps would be fine using tubes with the English dimensions?
If anyone has thoughts or experience with any of these questions, responses would be greatly appreciated.
David
David
