Loose sway bar
Loose sway bar
Hey kids,
is it normal that when the car is jacked up, that the rear sway bar is all loosey goosey? I can move it by hand no problem.
Wondering if I should tighten everything up while it's up in the air.
Cheers
Steiny
Cheers
Steiny
Re: Loose sway bar
Not normal. Bushings worn, nuts loose, something ain't right.
Re: Loose sway bar
Agreed.RRoller123 wrote:Not normal. Bushings worn, nuts loose, something ain't right.
Are you talking about a rear sway bar or the Panhard rod that goes between one side of the axle to the other side underbody of the car? If the latter, my shop manual shows 57 ft lbs for the bolts/nuts on the ends of the Panhard rod. Make sure those are close to spec, and if they are, the rubber bushings are probably shot.
- Nanonevol
Re: Loose sway bar
No rear sway bar on a stock 124.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
Re: Loose sway bar
Thanks guys,
I'm talking about this friend:
That's not stock?
That's not stock?
Re: Loose sway bar
That's the rear anti-sway bar all right. Perhaps a dealer option? In this case, I have no experience and so can't advise you on how it should "feel". Sorry...
- dinghyguy
- Your car is a: 1981 spider
Re: Loose sway bar
There is one on Mark ( one of my Fiat’s) and is not loose
Cheers
Dinghyguy
Cheers
Dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
Re: Loose sway bar
OEM or aftermarket the sway bar bushings and links should be firm and have only the give of the rubber parts noticeable and no play or gaps.
Re: Loose sway bar
+1
Re: Loose sway bar
All the hardware that holds this thing is SAE - per the dpo's forte. Grrrr.
But it seems he or she had a sensible idea to retrofit this. It does seem awful beefy for such a small car. I'd wager the donor was an 80's S10 pickup.
Could it be? The dpo made a sensible upgrade?
I'm gonna torque everything down with my buddy the impact gun and be happy.
Steiny
Steiny
Re: Loose sway bar
Just be careful to not over torque the links compressing the donuts too much. If the bar is excessively stiff they may have set them loose to compensate. When your sway bars are to stiff you can get this kind of diagonal wobble/rocking sensation on uneven pavement which will get amplified the tighter you compress the rubber donuts on the links.
Re: Loose sway bar
Steiny, help me out here: What's a "dpo"? I'm assuming it's not dastardly previous owner or devious previous owner, but several other possibilities come to mind such as D&*% previous owner, or D-Bag previous owner.SteinOnkel wrote:All the hardware that holds this thing is SAE - per the dpo's forte.
Am I close?
Re: Loose sway bar
That looks just like the aftermarket Addco swaybar that many vendors used to (and some still do) sell, and used SAE hardware. It shouldn't be loose jacked up or not. There's only a handful of nuts holding it all together, so it should be pretty obvious what's loose. I was never a fan of the stock rubber end links, so upgrading those is cheap, easy, and will make the bar perform more like it was designed to.
Re: Loose sway bar
Bryan, it stands for dreaded
Tightened everything up today. Should be a little less rattly now.
Oh and the dpo routed the brake line to go under the u-bolts...which means they would have been crushed if I had just clamped it down. Sheesh.
Such a simply job...why half ass it like that? The Fiat deserves better
Anyways, looks exactly like the Adco one from AR. $210 upgrade - sweet.
Cheers
Steiny
Cheers
Steiny
- red107
- Contact:
Re: Loose sway bar
I added the rear sway bar to my spider. I was underneath doing some maintenance and notice mine was loose. There is a metal spacer ( C channel) that goes between the the axle and the bracket. Make sure its still there. I was lucky I didn't lose mine.
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
