Replacing just lower BJ's without removing everything?
burlyb
Your car is a: 1982 Fiat Spider 124 2000 FI
Post by burlyb »
Is it possible to replace a lower ball joint without removing the lower A-Arm? I assume I'd still have to remove the lower shock bolt, compress the spring and remove sway bar bolts, but does the A-Arm have to come off?
burlyb
Re: Replacing just lower BJ's without removing everything?
Post by burlyb »
The answer is yes.
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
I think you can leave the spring and shock in place. Just make sure you have the a arm supported when you drill out the rivets. I know you can do the uppers.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
