Spring removal
Spring removal
I am currently redoing my suspension and I got everything down except for the spring removal/installation. Can someone walk me through this process as it is not something I want to get wrong. Thanks.
- Patron 2021
Re: Spring removal
For the front, I dropped the shocks and used this tool from amazon. Very easy! But be very careful, lots of stored energy. Watch your fingers!
OEMTOOLS 27200 Coil Spring Compressor https://www.amazon.com/dp/B00825PYBA/re ... aVHUNfetzH
78 Fiat 124
Re: Spring removal
I have come to prefer this outer style with the safety clamps:architect wrote:For the front, I dropped the shocks and used this tool from amazon. Very easy! But be very careful, lots of stored energy. Watch your fingers!
https://www.amazon.com/dp/B01N6L1QA6/re ... 456cd2a423
- dinghyguy
- Your car is a: 1981 spider
Re: Spring removal
i used two outside screw type units designed for McPherson struts. The problem is that the A-arms prevented me from aligning them exactly opposite from each other on the spring, so when the spring compressed it took up a it of a banana shape as well. Unfortunately the banana curled the wrong way, making it a bit of a pain to get everything back in place. I ended up having to compress, try, fail, un-compress, realign the two pieces, compress, try, fail, un-compress….etc until i finally got it right. Not a big deal just some time.
If you are buying a tool i would suggest the one that fits inside the spring is better, and that is what Fiat used.
The other key tool is the jack to push the a arm up a bit after the spring s more or less right to be able to get the ball joint nut on.
cheers
dinghyguy
cheers
dinghyguy
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
Re: Spring removal
I replace the compressor with chain after they are compressed when its tight like that. Then once the springs are loaded and the chain is slack they usually come out easily. I really don't like dealing with internal compressors as they can end up being a real bear to get out through the control arms on some cars plus wont be any good for the majority of cars out there which have struts. If you are only going to deal with the spider and never a car with struts then the internal may work out for some or else buy one of each type.
Sometimes I don't put the upper control arm back in place until after the spring is in and the lower control arm resting on a jack stand since its not needed until you install the knuckle and really just in the way if its hanging there.
Re: Spring removal
*UPDATE* solved, this picture is all I needed:
came from another thread that the first replier on this one showed me. Finished about a week ago, thanks for more advice though I can always count on you guys!
Re: Spring removal
That is exactly the internal compressor I have and have used successfully several times (different Fiats)Rotoariesarecool wrote:*UPDATE* solved, this picture is all I needed:came from another thread that the first replier on this one showed me. Finished about a week ago, thanks for more advice though I can always count on you guys!
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
Re: Spring removal
You can also get by with a mcpherson style compressor. Here's how (careful, this method is not for the faint of heart!). Take the spring and outside of the car compress it with the compressors. Now take some steel wire and wrap it around the compacted spring to keep tension on it. Remove the spring compressors, fit spring in car. Make sure it's sitting snugly in the bottom control arm and the upper bushing. Take a jack an place it underneath the lower arm. Jack it up until the spring has nowhere to go save for where it should be. Now cut the steel wire.
The benefit is that the shock can stay exactly where it is, because on the driver's side taking that sucker out is a nightmare.
