Corrections/improvements VERY welcome. NOTE: these are for a 1972 Spider, 124BS10057244, and taken from a copy of the Fiat service manual for this series of cars. Double check your own vehicle's settings, since I suspect they differ over the years.
Part/Torque Setting: FT/LBs
Front:
Upper C Arm Spindle: 72
Lower C-Arm Spindle to xmember: 44
Lower C Arm Spindle end nut: 72
Upper/Lower King Pin: 15
Ball Joint Spigot Nut: 45
Caliper Assy to King Pin: 44
Top Shock Nut: 11
Lower Shock Nut: 36
Sway Bar-ALL: 11
Steering pin nuts on ball joints: 25
Rear:
Trailing & Panhard Bolts ALL: 72
Top shock nut: 11
Lower Shock Nut: 11
Drive shaft to pinion flange: 28
Brakes:
Disc Bolts: 15
Fr Caliper to mounting plate: 43
Caliper Block Bolts F & R: 35
(It all lines up better in WORD....
Sorry to have been so scarce last few months. After completing a bunch of house projects last winter/spring/summer, I enrolled in a year long diploma program for cabinet making at the local tech college. It's been a blast, but very time consuming. Done this May, so there'll be more time for Fiat related activities!
Neil
