Here's my recipe:
- Pre-cut and bound black carpet from Vick Auto. The picture on their site is terrible, but maybe you can see it better here? It's a short pile, rather than a loop. I've seen floor mats thicker than this stuff, but the price was right, and if I do a decent job on the install, I'm sure it will be fine.
- ThermoTec "The Suppressor" - heat and sound insulation.
- ThermoTec ThermoGuard FR
- POR-15
I'm thinking I'll use The Suppressor on the firewall and transmission tunnel, behind the kick panels. If I get ambitious, I might use some on the doors too. I'll use the ThermoGuard FR, which has a 1/4" pad, on the floorboards and areas where I will need the padding. That's not a lot of padding, but I'll be getting floor mats too.
What I'm pondering: The ThermoGuard FR lays with the felt side up. I'm concerned that all those little precut carpet pieces are going to slide around, so I'm thinking I'll use some spray adhesive to attach the carpet to the insulation pad. But I wonder how well that's going to hold (carpet to thick felt, basically), and whether there's a better way. I saw a guy on YouTube using 3M ribbon seal (normally used for windshields). Has anyone tried that? I'm skeptical, but hey, that guy's got a you tube channel, so he must know what he's talking about!
As always, I appreciate your input!
ThermoTec: https://www.thermotec.com/products/soun ... t-barriers
