Lowering steering wheel
KnightDriver
Patron 2019
Patron 2019
Your car is a: 1979 Fiat 124 Lusso Spider
Post by KnightDriver »
Is there a way to lower the steering wheel in a 1979 Fiat spider? The position of my wheel is quite high, which I gather is the original position and it feels like I’m driving a school bus.
La Bella Macchina
Forgive me for I know not what I do. Seriously, I am probably way over my head...
zachmac
Re: Lowering steering wheel
Post by zachmac »
In theory you could just add some sort of spacer block and longer bolts between where it bolts up just under the dash. It has two articulating joints so it should still function fine. Just be sure to add longer bolts / way of securing it at all four points on that bracket. The rear two are small bolts that capture little flat guide plates through slots in the steering wheel bracket. I guess they could be replaced by longer bolts as well.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
You could use a smaller steering wheel.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Odoyle
Your car is a: 1983 Pinafarina Spider
Post by Odoyle »
These cars were built by people with long arms and short legs. If you want vintage Italian with adjustable steering column, you'll need to get a Ferrari.
focodave
Post by focodave »
KnightDriver,
It is very easy to safely lower the wheel by adding some spacers and longer bolts to the aft side of the steering shaft support bracket.
See photos, below, of mine.
I added just 3/8" of total spacers (3, 1/8" thick washers) and it lowered the wheel to a much more "normal-looking" and "normal-feeling" position.
You will be surprised how little amount of spacer it takes to lower the wheel substantially.
Dave
1970 MGB GT (my other hobby)
SuperCoupe
Your car is a: 1973 124 Sport Coupe
Post by SuperCoupe »
Odoyle wrote:These cars were built by people with long arms and short legs. If you want vintage Italian with adjustable steering column, you'll need to get a Ferrari.
That is really a myth. The real reason is Italians hold the wheel from the bottom - typically 8 and 4 and feed the wheel input through the lower part of the steering wheel. Shuffling the wheel as they go. They rarely reach over the wheel. That myth of long arms and short legs is an unfortunate leftover stereotype from non-Italian road testers.
Below is an example:
In the old Safe Motoring Manuals delivered with the cars in the 60s and early 70s, the recommended hand position is the left slightly above center and the right slightly below (rule of 10 and 4).
Watch the technique demonstrated in this Lamborghini Miura from a well known movie...
https://www.youtube.com/watch?v=2lqtNThufkk
If you practice the technique, you get used to the position and everything makes sense. I grew up driving these cars and prefer it, plus it keeps the car's originality and uniqueness. Give it a try!
The funny thing is now with the event of airbags, shuffling the wheel is now the recommended technique. Looks like the Italians were ahead of the game!
Current:
'73 Fiat 124 Sport Coupe
'82 Alfa GTV6
'12 500 Abarth
'18 Alfa Stelvio Sport
Previously owned:
124 Sedan and Wagon, couple of 850 and 128 sedans, 71 and 72 124 Sport Spiders, 76 Lancia Scorpion, 87 X1/9. 500X Trekking Plus
