After owning and working on X1/9's for almost ten years I finally obtained the Spider I've always wanted.
That said my recently obtained 84 Pininfarrina Spider needed its emblems replaced. I purchased the emblems, opened the trunk and was ready to remove the retaining clips that were readily accessible on my X's. Low and behold NO clips! In fact no access to emblems from inside the trunk or under the insulation of the hood.
I feel like an idiot asking this but is the only way to remove an emblem prying it off.
I'd rather be an idiot and ask than possibly damaging very nice paint. Thanks in advance.
Emblem Removal / Installation
Re: Emblem Removal / Installation
The badges are either held on buy a small nut or a plastic/rubber clip on the pins. Getting them off is a real PITA as you have limited access. I recall using needle nose plyers and it taking me some time to remove both badges and replace. Decided to use some adhesive for the rubber backing and the emblem in addition to the emblem clips that came with the new badges.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- Danq
On the '81 i have, the rear emblem attachment hardware was hidden under in the interior bracing of the trunk lid. The PO bent the metal to gain access, about a 1/2".
Dan
1981 spider 2000
1981 spider 2000
