Page 1 of 1
Cleaning up the space under the wipers today
Posted: Sun Feb 11, 2018 9:47 pm
by mamsterla
Today I decided to remove the surface rust in the space under the wiper panel. It has the vent and mine was just ugly. I had researched the task and decided to use POR products - the metal prep and then POR-15 black. This space is covered, so I did not mind painting it black (cue the Stones).
Here is the sequence:
Before: you can see the surface rust all over this area
During: here you can see post the metal prep. I also used a steel wire brush to help the metal prep do its thing. After the metal prep, I sanded with a block and brought out the dremel with a wire wheel attachment to get some of the corners. It really removed almost all the rust in 20-30 minutes
After: here it is after 2 coats of POR-15 black. I could have done some removal of the good original paint, but the POR-15 did cover it with the second coat.
Re: Cleaning up the space under the wipers today
Posted: Sun Feb 11, 2018 10:45 pm
by AriK
Great work!
I had good luck with Por15 myself.
Many folk speak against it and have other prefences (they claim it peels away) but i believe that not enough attention was taken on the prep. Most effort should be on the prep rather than the Por15 application: Five years later, after inspection, the Por-15 still doesn't disappoint, still adheres and maintains a blinding shine.
Posted: Mon Feb 12, 2018 12:56 am
by mamsterla
I am thinking I may do the floorboards down the road. Mine has some rust, though I think a little less that what you have shown. I am not happy with the old padding in there. I will probably just tear it all out, get new carpet and get some of the modern deadening material. Thanks for posting. Looks like a good thing to do in the not too distant future.
Posted: Mon Feb 12, 2018 4:08 am
by AriK
I was really pleased with how the job was progressing. Much of the first photo shows rusted residue and rotted jute & tar that was left at the surface from decades of neglect. I guess that’s where the typical Fiat smell we’re all familiar with originates from. From start to finish (assuming 2-3 hrs a day after work) including carpet washing, reconditioning the delicate wire loom, grinding and proper drying time before the 3rd step Por15, it took about a week.
The results were very satisfying. There was a tiny weak spot around a drain hole that required strengthening with fibreglass cloth.
Obviously it’s a job that should be done sooner than later since the effects are irreversible.
Enjoy.
Posted: Wed Feb 14, 2018 5:39 am
by QuebecFiatSpider
Great looking job Arik, congratulations
I'm planning to do my floor also next year like you did...
Posted: Wed Feb 14, 2018 6:02 pm
by baltobernie
How about top-coating your work with some original red paint? Brush application would be fine. POR-15 says that their product degrades under sunlight. I don't know if the product weakens, discolors, or? but they do add this caution on their label.
