AFM flap
Leonard124
Your car is a: 1980 Fiat Spider 2000
AFM flap
Post by Leonard124 »
Does anyone know which 2 wires act as the switch for the fuel pump in the AFM ?
Intermittant power to fuel pump...so I am suspecting the AFM flap or the double relay.
When I move the flap in the AFM with ignition ON, sometimes the pump works and sometimes it does not.
When the pump does not run, I do not hear the relay click under the glovebox.
Leo
1980 Fiat spider 2000 f.i.
Re: AFM flap
Have you removed the black plastic cover from the top of the AFM?? I like to remove it and inspect the fuel pump switch contacts and the rest of the workings.
Leonard124
Re: AFM flap
No...wanted to see which contacts they were without removing the lid.
Was able to figure out the contacts with the use of an old wiring diagram I have.
I did this at the combination relay.
The contacts work good...so it is not the AFM switch.
Seems the double relay is the culprit.
Not powering the fuel pump.
thanks
Leo
ORFORD2004
Re: AFM flap
Post by ORFORD2004 »
Open you double relay, you may have broken soldering.
Re: AFM flap
I'm for opening things and looking/inspecting. For me it also helps me understand how things function.
The connectors on the relay can be swapped and then the relay will not function. So I mark the connectors and relay to be sure I replace them properly.
The small female connector on the heavy brown wire sometimes becomes intermittent and needs tightening.
Leonard124
Re: AFM flap
So it seems it was the combination relay. Installed a new one and after driving 600 kms, all is good.
Now i guess I can open up the old one and see what went wrong.
Leo
81SPIDERMATT
Re: AFM flap
Post by 81SPIDERMATT »
i would like to know what you find and how easy/hard it was to open and inspect
