I am starting to replace all of the old cloth covered rubber fuel lines in the rear end of the spider. As the metal lines go forward, ahead of the rear wheel well, there is a small section of cloth covered rubber hose (two lines) just forward of the rear jacking point on the drivers side. Just near where the front of the long trailing arm connects. This small section appears to connect two sets of hard fuel lines, one from the rear, and the other going forward into the cabin. However, when trying to cut through the hose for removal, it appears that the metal fuel line may run through the entire length (approx. 7.5").
Does anyone have any experience with replacing these?
