Easiest way to empty my fuel tank?
njspider
Your car is a: 1982 spider
Post by njspider »
I need to replace my weeping fuel tank which about 3/4 full. Is there a way to use the car's electric fuel pump to empty the tank without harming the pump? What other options are there without making a major mess? Thanks
BwBrown
Your car is a: 1970 Spider
Re: Easiest way to empty my fuel tank?
Post by BwBrown »
Put the top down and go for a long ride?
But yes, I have used the fuel pump - takes awhile.
Dushore, in Northeast PA
1970 124 Spider (red) and a 1979 2000 Spider (Ferrari yellow)
Also: a pair of 1952 MGTDs
1972 Fiat 850 Spider
1965 Chevelle SS Convertible
1975 Corvette
1986 Lada Niva
courtenay
Post by courtenay »
Do what Brown said, then pull the hose off the intake side of the fuel pump and drain the residual fuel into a basin under the car.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
I could be wrong but I think the fuel will siphon out of the tank all by itself if you remove the hose at the fuel pump. When I replaced my fuel pump I had to pinch off the line to stop the fuel flow. The pick up sits close to the bottom of the tank so about 1 inch of fuel remains in the tank.
johndemar
Your car is a: 1976 Fiat 124 Spider
Post by johndemar »
My first thought was a large sharp screwdriver and a big hammer. :D
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
