Removal of rear brake discs 1979 2000??
maxdog
Patron 2019
Patron 2019
Your car is a: 1979 spyder 124
Post by maxdog »
HI
I'n on my way to replacing my rear axle oil seal, every thing came apart fairly easily until I tried to remove the rear disc, to get to the snap ring retaining the axle shaft .
The disc won't move ,I can't see any obvious way of shifting it.The Fiat shop manual is silent on rear disc removal , there's nothing helpful in the Brake and Axle sections . "I thought the other guy was doing it , not my job, I'm not responsible"
I,ve soaked the disc in penetrating fluid , whats next ?? Prayers ,Applied violence with a "Birmingham screwdriver"[ a 7 lb lump hammer ] , heat , jacking screws in the two small tapped holes , a big hairy puller with a 36 inch pry bar ??
Any suggestions , please ?
Maxdog
bobplyler
Patron 2022
Patron 2022
Re: Removal of rear brake discs 1979 2000??
Post by bobplyler »
Should just pull off. Did you undo the two alignment bolts?
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
maxdog
Patron 2019
Patron 2019
Post by maxdog »
Alignment bolts ?? Are these the two small bolts that hold the spacer in place on the front of the disc ?? If so I removed them . I'm looking at a bare disc face with nothing holding the disc on, except perhaps some rust .
So far I've tried dosing with penetrating oil followed by gentle persuasion with a hide faced hammer , with no success, What's the next step ?? Can I use longer bolts in the alignment bolt holes to push the disc off ?? Do I need a big puller , the centre of the axle shaft looks as though it's machined to accept the centre bolt of a puller. What's next ,Heat ?? Graduated violence .??
Maxdog
micbrody
Your car is a: 1981 fiat 2000
Post by micbrody »
https://youtu.be/7IQ8Hf2UiAE
There is a tool that has three arms that pull back of rotor in three places relative to the hub. You can see it in video.
With that said:
I did it a crude way on my rear rotors (both stuck).
I had new rotors to install (4 delivered for $56!!!!); so even if I damaged rotors, I didn't care.
I first took soft rubber mallet at tapped from behind; no luck
I then took metal hammer and pounded from behind going around in circular fashion along edge. They eventually loosened. The hammer did cause some nicks at edge of rotor; but not to effect brake to pad surface.
When they broke loose, there was a layer of rust on hub that needed to be sanded to replace rotor.
I wrote a detailed thread labeled "rotor replacement". My new rotors were not sitting flush. I sanded rust off of hub......but the problem was the rust on edge of hub that sits inside the back of rotor (read thread)
