Relay
fiat218
Relay
Post by fiat218 »
I was playing around with the wiring on the lime green 69 i have/ lets just say the wiring is all cut and some missing
Anyways i have the instrument panel completely out of the way and i pulled all the wiring down from behind the dash to the floor so i could sort it out, i notice right along the upper underside of the dash there is a relay ,but unplugged , what would that be for ? Dont see any unused plugs to plug it in, but there many unexplained wires cut, so maybe The Who ever cut that plug connection off, any one have a photo of the wires going to that
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
klweimer
Re: Relay
Post by klweimer »
Fiat218,
PM me with your email address and I'll send you a scan of the electrical troubleshooting manual. It has all the component locations.
Kirk
fiat218
Re: Relay
Post by fiat218 »
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Relay
Post by fiat218 »
I am starting to believe there a lot missing for the wiring.i have played with this for at least 8 hrs and I have not got one thing to even work' maybe it just a parts car.there is some rust issues to.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Relay
Post by fiat218 »
In the wiring diagram .69 to 73
It shows number 37 flasher,indicator 57
If you look at the full diagram 37 looks like a relay of some sort' can some one help me uderstand what 37 is . Thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Relay
I don't have the diagram in front of me, but it's common to find the key buzzer disconnected
Re: Relay
I'm not sure this applies to your car. Early Spiders had a round signal light flasher, a rocker switch to turn on the emergency flashers and a separate square flasher that was used in 4 way flasher only.
Hope this helps
Here are some photos of a removed emergency flasher with wires attached.
fiat218
Re: Relay
Post by fiat218 »
That's what i am missing , the flasher stuff,i got the rocker switch
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Relay
Post by fiat218 »
So Cal Mark wrote:I don't have the diagram in front of me, but it's common to find the key buzzer disconnected
That's true, are hose the two wires that you see sticking out of the ignition switch, i think it a small pick and white, or both white i seen
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Relay
Also I just looked at the schematic you mentioned and believe the 4 way flasher indicator is item # 59 not 57 that the component list states. Sometimes even factory information has errors.
fiat218
Re: Relay
Post by fiat218 »
Send that part in that photo :). Exact wiring. That i see on mine
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Relay
Post by fiat218 »
I seen that, i was saying if you looked at #37 it like it pointing to 57 too
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
