Hi Everyone. I am in the middle of restoring a 1984 spider. I am not able to get it to run because the ECU is not sending a ground pulse to the fuel injectors. In reading another thread on this site, I believe the issue is I do not have a ground wire from the firewall to the passenger side cam cover nor do I have one from the Coil Block to the cam cover. I can easily put these on, but I would really like to see where these mount on the firewall, cam tower and coil block. Would someone be willing to take a few pictures for me of what these look like? I will preface this by saying my wiring harness on the passenger side was some home made contraption - see below. I needed to take this out and I am trying to locate a used one before I try and make one myself. That is why there is no free wires hanging around - they are likely somewhere in this clump of wire with cutoff terminals.
Thanks so much!
Rob
