coil wiring
- Your car is a: 1980 Fiat spider 2000
coil wiring
Need a little help. I have a 1980 FI spider. Just want to know what color wires are connected to the positive side + of the coil and what colors are connected to the negative side - . I replaced a connector and I just want to be sure they are in the correct position. Thanks
Re: coil wiring
The + side of the coil has the black wire for the filter capacitor, the pink wire from the ignition switch and the red wire from the ECM located under the coil. The minus or D terminal of the coil has the black wire from the ECM , a brown/white wire for the tacometer and if the car is fue injected another brown/white wire for the fuel injection computer.
Hope this helps
Hope this helps
Re: coil wiring
Thanks a lot......I'm having an issue with the tachometer. It seems to be jumping every now and then. There seems to be a slight miss. Wondering if the coil or the pick-up can be going. Never did that before.
