Tonight's Issue
davery
Your car is a: 1985 Spider
Tonight's Issue
Post by davery »
So I'm finally to the point where I putting the center console switches back in. I put the hazard, power windows switches, etc in the console before I installed the console and plugged the switches in. I wanted to make sure the power windows were going the correct way while I could easily reverse them. Everything worked as it should. I installed the console and now the power window switches are not working. I took the console back out, removed the window switches and plugged them in and no windows. Fuses are OK. Seems like a strange time for the switch to go bad but I guess it could go bad at anytime. So before I buy another power window switch, anyone have anything to try?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
Re: Tonight's Issue
Not sure with the pinna but on the Fiat Spiders there is a relay that supplies voltage to the power window fuses 11 & 12. The relay is mounted under the glove box
davery
Re: Tonight's Issue
Post by davery »
Don Avery
1985 Pininfarina
2011 Eos
davery
Re: Tonight's Issue
Post by davery »
davery wrote:
spider2081 wrote:Not sure with the pinna but on the Fiat Spiders there is a relay that supplies voltage to the power window fuses 11 & 12. The relay is mounted under the glove box
I pulled that relay panel down when I removed my dash. I don't remember seeing any fuses, though. I will go back and look tomorrow. I found a diagram of the relay panel. It seems there is a power window relay, in addition to fuel injection, and a couple seat belt relays. I have not really looked at these very much. Can one on the other relays be used to test in place of the power window relay?
Don Avery
1985 Pininfarina
2011 Eos
davery
Re: Tonight's Issue
Post by davery »
I tried to jump the switch to see if the switch was bad. Still no windows. I assume my next two options would be the relay or the ground. Do anyone know if there is any way to check the relay without purchasing a new one?
Don Avery
1985 Pininfarina
2011 Eos
