Not starting
davery
Your car is a: 1985 Spider
Not starting
Post by davery »
I have been working on the electrical under the dash and now the car will not start. Not even with a jump. Any ideas where I should start first?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
Re: Not starting
More information is need from you. Does the car turn over. Do the warning lights in the instruments lite when key is turned etc
davery
Re: Not starting
Post by davery »
spider2081 wrote:More information is need from you. Does the car turn over. Do the warning lights in the instruments lite when key is turned etc
The car turned over once, but no longer does. Not even with a jump. I have the speedo and tach gauges currently out of the car, so the lights are unknown. I will not be able to spend time on it until Thursday. My first thought was to check power to the starter.
Don Avery
1985 Pininfarina
2011 Eos
davery
Re: Not starting
Post by davery »
So it turns out the battery was completely dead. So much so that I couldn't even start it with a jump. I've never had that happen before. I have been working on the dash wiring and am wondering if maybe there is a power draw somewhere. I have all the dash back in but the digital clock (which I'm replacing with an analog clock) and the courtesy light. Is it possible one of these being removed causes a constant power draw? Thanks!
Don Avery
1985 Pininfarina
2011 Eos
