Door jamb switch
Nanonevol
Door jamb switch
Post by Nanonevol »
My courtesy light works by the switch on it but does not go on when the door is opened. Can someone tell me where the switch is on the door? I see nothing.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
fiat218
Re: Door jamb switch
Post by fiat218 »
On the inside mid between hinges
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Post by fiat218 »
That's if there all the same place
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
joelittel
Post by joelittel »
It's a small round, white plastic, button that makes contact with a conical rubber piece attached to the door.
The rubber piece gets deformed and is no longer able to push the button in when the door is closed.
GeorgeT
Your car is a: 1982 Fiat 124 Spider
Post by GeorgeT »
joelittel wrote:It's a small round, white plastic, button that makes contact with a conical rubber piece attached to the door.
That would cause the light to stay on. When the door is opened the button "pops" out and grounds the light circuit causing the light to go on, when the door closes the button is pushed in and the circuit is opened and the light goes out. You may need a new door switch or simply cleaning any rust where the switch is. You can check the wiring by pulling the wire off the switch and grounding it; if the wiring is good the light will go on.
Nanonevol
Post by Nanonevol »
Ok, I see it now. Or I see where mine used to be . Switch is missing on both sides but I see the rubber bumper mentioned. Thanks, folks! I'll see if I have wiring inside the door then look for a couple switches (Only $3.50 a piece at A/R!).
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
Post by RRoller123 »
Tutto Tomorrow at The Larz, Nick! Hope you can make it.
Pete
The courtesy light door switch is mounted in the door jam between where the door hinges mount to the body of the car. The switch is not mounted in the door. The wires in the door are for electric windows. Fiat installed those wires in all the cars even ones with hand operated crank windows.
Nanonevol
Post by Nanonevol »
Right, thanks. The bumper is on the door, the switch on the car by the hinges.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
