Anyone ever seen this before? Here's a video...
https://youtu.be/iyctOxmaGGA
Everything was fine a few days ago. No changes to electrical system or car. Any idea what could cause this to happen?
Richard
Temp and fuel gauge go up when lights turned on
- rjkoop
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Re: Temp and fuel gauge go up when lights turned on
The ground for the gauges is weak. I ran an extra ground wire to the gauges and that stopped it.
Agree with the bad ground. I think the wire diagram for the dash lights is deceiving in that it shows a white /black wire as the gauge's light ground. I believe the light bulb actually makes its ground connection to the instruments metal case. The metal case of the instrument is also the grounding point for the instrument itself and the whit/black wire is connected to the metal case. This makes the light ground and the instruments ground a common wire. If that wire is not 100% grounded power to the light will affect the instruments accuracy.
- rjkoop
So I took apart the dash and wasn't able exactly where the instrument ground is on my '81. I guess each gauge has a white/black wire that goes into the harness and is grounded somewhere? Wasn't sure what I needed to add where. Tried cleaning the connectors (sanding and electrical cleaner) on the fuel gauge just in case and no better. Here's a few pics.
Fuel gauge
Fuel gauge connection
Middle of instrument cluster
Right of instrument cluster
Fuel gauge
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
It does not matter where they ground. Just tie into the ground wire somewhere (I think the white/black wire) and run an extra wire to ground.
- Your car is a: 1985 Spider
It seems my go to ground under the dash is the heater fan ground which is to the left of the center console.vandor wrote:It does not matter where they ground. Just tie into the ground wire somewhere (I think the white/black wire) and run an extra wire to ground.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- rjkoop
Yep. I just wanted to check the existing ground point 1st to ensure it's clean before adding a new ground.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- rjkoop
A few more basic questions...
And if I add a new ground do I just strip an existing ground wire (ex. from the fuel gauge wiring connector), solder in a new ground and then connect it somewhere to the body behind the instrument cluster? Also what gauge wire should I use?
Richard
Richard
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- rjkoop
Turned out I didn't need an extra ground. Once I found the grounds (to the right of the steering column just under the dash) I cleaned them and problem solved.
Richard
Richard
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Good news on your repair.
There is a Fiat publication " Spider 2000 Electrical Diagnostic Manual 1980-1981" available on line that I find very helpful. I tells you the general area of all the connectors and the location of all the grounds.
- Your car is a: 1979 Spider 124
Is there one available for a 79? I don't have any electrical issues yet, but it would be nice to have that resource if/when it happens.spider2081 wrote:Good news on your repair.
