Rear Brakes
Golf1
Rear Brakes
Post by Golf1 »
Hello, I have replaced my rear calipers and pads. Now the caliper Is over engaging sticking. Any suggestions? I have done the recommended adjustments via the big white garage manual?
Thanks in advance.
DieselSpider
Re: Rear Brakes
Post by DieselSpider »
Did you ensure that you screwed the brake pistons all the way back in on the self adjuster studs via the slot in the outside end and then give them an extra twist so the slots alined with the pins in the backing of the inner brake pads?
