Door Pulley Mount Solved
Nitrate
Your car is a: 1981 Fiat 2000
Post by Nitrate »
81. 2000. Turns out the PO mounted the flat bar/pulley assembly thru the wrong mounting hole. It can be confusing because the correct holes are actually slots which are close to the holes. I also assumed that a bolt would most likely go thru around hole rather than a slotted hole. I'm surprised the window worked at all because the pulley geometry was off. Oh yeah, the Duh moment came when it occured to me to check the other door!! That one showed the slotted mounting. How long have I been doing this stuff? Rich B
Fiatlanta
Your car is a: 1979 Spider 124
Re: Door Pulley Mount Solved
Post by Fiatlanta »
That's the scary part about getting into 30+ yo vehicles...never know what craziness the prior owner may have done...
Fiatlanta
Post by Fiatlanta »
Double tap
