Mystery wires in trunk.
- Your car is a: 1982 spider
I have 2 wires in the left side of the trunk that terminate near the gas filler. One is blue/red, the other is green/white. Both have factory connectors but are not plugged into anything nor can I find anywhere they look like they would go. All my lights work. Neither wire is hot with the key on or off. I can't find them on my wiring diagram. Any ideas? thanks
- courtenay
Re: Mystery wires in trunk.
Pre wiring for a power antenna? If so, there should be corresponding wires behind the dash. They'd be connected to wires coming out of your radio that would activate when you turn the radio on.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
One could be for the trunk light, which always seems to be missing.
Power antenna wires would be in that area. Their colors are: Dark blue/red and Light blue/white, They originate near the center console where the switches would be mounted. Hope this helps.
Sounds like a good theory. The manual antenna in the car is definitely not factory. Maybe it replaced a power unit that crapped out. Thanks for the input.
- Your car is a: 1982 Fiat 124 Spider
These cars did not have a factory installed radio (dealers installed them) but they were pre-wired for a power antenna.njspider wrote:Sounds like a good theory. The manual antenna in the car is definitely not factory. Maybe it replaced a power unit that crapped out. Thanks for the input.
Is this why antenna placement doesn't have a standard position?GeorgeT wrote:These cars did not have a factory installed radio (dealers installed them) but they were pre-wired for a power antenna.njspider wrote:Sounds like a good theory. The manual antenna in the car is definitely not factory. Maybe it replaced a power unit that crapped out. Thanks for the input.
I've seen some very near the gas lid and some much closer to the convertible top.
1979 Fiat 2000 "Luigi"
I had one where the antenna was on the right front fender.profcucchi wrote:Is this why antenna placement doesn't have a standard position?GeorgeT wrote:These cars did not have a factory installed radio (dealers installed them) but they were pre-wired for a power antenna.njspider wrote:Sounds like a good theory. The manual antenna in the car is definitely not factory. Maybe it replaced a power unit that crapped out. Thanks for the input.
Yeesh...GeorgeT wrote:I had one where the antenna was on the right front fender.profcucchi wrote:Is this why antenna placement doesn't have a standard position?GeorgeT wrote: These cars did not have a factory installed radio (dealers installed them) but they were pre-wired for a power antenna.
