What are they?
Ellie
Your car is a: 1982 Pininfarina Spider 2000
What are they?
Post by Ellie »
As my electrical knowledge extends only to Leggo, can anyone tell me what the two connectors are that are in the same line as the spark plugs? For example, the plugs are all in a row but (I think) between the 1st and 2nd plugs and between the 3rd and 4th plugs there are electrical connections.
This is in an '82 with EFI
81SPIDERMATT
Re: What are they?
Post by 81SPIDERMATT »
I wanna say temp sensors .... although I cant say why there are 2 of them .... one tells temp and one pegs the needle when things get too hot .... I think ...... MATT
Re: What are they?
Post by RRoller123 »
That is it, the rear one is usually the one that pegs the needle if it all overheats, but either one will fit in either position I think.
lglade
Re: What are they?
Post by lglade »
One is the coolant temperature sensor for the gauge and the other is the temperature sensor for the idiot light.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
Ellie
Re: What are they?
Post by Ellie »
Awesome, thanks for that. All good!
Re: What are they?
No idiot light, it pegs the gauge. But a bright light as it hits some predetermined temp wouldn't be a bad idea. Might keep us from constantly and directly watching the temp gauge.
Pete
4uall
Re: What are they?
Post by 4uall »
Ellie
Re: What are they?
Post by Ellie »
While I am information gathering, what is the grey plastic bag that is clipped to the side wall in the engine compartment? Passenger side above the front wheel and in that IA U tube clip its right there.
GTO
Your car is a: 1973 Spyder 1756
Re: What are they?
Post by GTO »
It holds the windscreen washer liquid.
Ellie
Re: What are they?
Post by Ellie »
Yup, I thought so. Thanks for confirming. :)
micbrody
Your car is a: 1981 fiat 2000
Re: What are they?
Post by micbrody »
I was wondering why they had two temperature probes, with one that only pegs. One would think the variable one should suffice.
Well, I experienced why there are two :
I noticed on a hot day, my engine was running hot; fan wouldn't come on till 240; I was worried that there was an air lock (I had recently changed a heater coolant valve); or that water pump was failing.
I brought car home. Used infrared thermometer on engine; coolant t, etc... All the temperatures seemed normal ; seemed like my gauge was incorrect. I then remembered I had (earlier that day) removed gauge panel to clean up contacts on the 11 pin connector (intermittent dash turn indicator/and some occasional crazy tach readings). When I inspected temp gauge with car electrified , the gauge would change as I jiggled one of the connectors. Since the variable gauge is based on variable resistance, turns out I just need to clean contacts on gauge.
Conclusion: the pegging gauge is the "fail safe" to definitely indicate overheated engine
