Help! Parts, Bushings Ect...
Spider112515
Post by Spider112515 »
Okay so i've got this little gem running great. Rebuilt the carburator and replaced the cracked distributor cap and broken rotor as well as the original accelerator cable-still sticks a bit keeping the idle higher than desired. Here's the next issue:
Control arm and sway bar bushings need to be replaced so I've been looking around and asking questions. I've found bushings but I'm being told that many of the replacement bushings are garbage and wear out very quickly or have fitment problems ect. Can anyone give me a good source for these parts. I have a number of online suppliers but no idea who has the best or worst parts. Thank you all in advance for sharing!
juvius
Your car is a: 79 spider
Re: Help! Parts, Bushings Ect...
Post by juvius »
autoricambi.us
I have the urethane bushings in stock as well as original style rubber
davery
Your car is a: 1985 Spider
Post by davery »
So Cal Mark wrote:I have the urethane bushings in stock as well as original style rubber
What are differences between urethane and rubber bushings?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
124JOE
Post by 124JOE »
rubber bushings are known to fail very quickly
and urethane are great but can be noisie
our urethane are designed for street use and are NOT noisy
juvius
Post by juvius »
Hey mark.... sorry.... I don't know what I was thinking... I should have mentioned you as well.
Spider112515
I "heard" the urethane bushings do get noisy after a while but the rubber ones are cheaper and closer to stock. I really don't want noise and I do want longevity. The noise will keep me wondering if something is wrong. Help.
124JOE
Post by 124JOE »
ok mine are not urethane
mine are delrin
and im not sure the Aarms are straight so they may be binding (shotty work done by a shaddy shop
causing NOISE
sorry mark
