What Siain for Dash Wood
I have a 1981 2000. I don't care for the wood used in the dash and other areas. I can get Beechwood finished in Oak Stain or Beechwood finished in the original factory color. These are avaliable from Allison Fiat. An informal survey: Which do members prefer? Thanks, RB.
Re: What Siain for Dash Wood
Natural mahogany, with a satin spar varnish finish. No stain!
I did mine this past winter, and it turned out great! I used 1/4" plywood for the new dash base, and covered it with a natural mahogany veneer. All the materials, except the spar varnish, came from veneersupply.com.
The red mahogany looks so much more 'rich' than the beechwood, in my opinion.
Dave.
Dave.
Frog2Spider
'81 - 2000 Spider
Frog2Spider
'81 - 2000 Spider
- 70spider
- Your car is a: 1970 Fiat spider
When I did my dash I made it myself and used solid wood from http://ocoochhardwoods.com/scroll_saw_lumber.php. I like the choices of different types available, plus I didn't want to mess with gluing veneers. Here is how it turned out:
note: if you make your own be sure to poly both sides otherwise the wood will warp. Good luck
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
the beech is very close to the color the early Spiders used.
- Your car is a: 1985 Spider
I just ordered the Madrone Burl veneer for my dash. I can't wait to get started.Nitrate wrote:I have a 1981 2000. I don't care for the wood used in the dash and other areas. I can get Beechwood finished in Oak Stain or Beechwood finished in the original factory color. These are avaliable from Allison Fiat. An informal survey: Which do members prefer? Thanks, RB.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
That is what I used, love the look of it. Standard on the Pantera back in the day.
Pete
Pete
My personal preference in what I consider harsh areas such as wood veneer in a automobile is to use door skins and not woodcrafter's veneers.
http://www.birchwoodbest.com/doorskins.php
Before suffering a crippling injury I maintained, designed and built the equipment used in a series of 3 architectural mill-work facilities in New England that made Doors and Windows along with just about any Custom Trim or Furnishing one could imagine and was spoiled with all the Exotic cut-off Door Skin pieces one could dig out of the dumpsters and make use of in small personal projects. Door Skins have a much thicker surface than a veneer since they are intended for years of use in high traffic situations so they hold up better on dashboards, armrests and console tops than a veneer that's only a few mills thick. On some the surface veneer is almost a full 1/8 inch thick.
It's funny you mentioned door skins. I am using door skins to make the curved dash pieces on my 85. Originally I was just going to stain the birch ebony, but now I am going to attach Madrone Burl veneer.DieselSpider wrote:My personal preference in what I consider harsh areas such as wood veneer in a automobile is to use door skins and not woodcrafter's veneers.
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
