Ignition system
Baz
Your car is a: 1977 Fiat Spider
Ignition system
Post by Baz »
Mark, I have installed the Computronix ignition system and no problem whatsoever. Works a treat and I recommend Spider owners having a look at this system. Thank you for your prompt and considerate service. Can you advise me the recommended spark plugs for use with this unit. Advice sheet destroyed. Are they NGKV-power ??
Many thanks again for your help.
Baz
Re: Ignition system
we use NGK but Bosch Super work well. Standard copper core, no platinum nor iridium
